ReduceMesh Command is Not Working in Rhino 8 SR13
with each rhino 8 update, they fix something, and ruin something else that was working.
As you can see in the video, the ReduceMesh command doesn’t work.
Anyone Encountered this problem using rhino 8 SR13?
Hi Joe -
A bug on Windows that required a user to press Preview in the ReduceMesh dialog was fixed in Rhino 8.14 - RH-84405 ReduceMesh: Mesh won’t reduce without preview
You can change the download frequency to install the public release candidate, or wait for December 10th when that becomes SR 14.
Hi Wim,
Thank You very much for your helpful response.
P.S. I tested the “Press Preview” in rhino 8SR13 and it worked. Problem Solved.
