Hi RMA - with many objects selected and processed, we get the 0-100% repetitive reporting but no idea how many objects have been processed. Would be nice if it was also showing Object 3/30, 4/30, 5/30 etc. in case the input is more than 1 object…
Also - in case 1 of the many objects reduction fails, the command gets canceled losing all the good reduction that already happen. I’d rather see it process all it can and then highlight the objects that were not processed…
Hi David - that’s great. I can see it now. Is the handing of the other issue fixed too ? I can’t find a mesh that gave me errors last time…). What happened to the accuracy setting (Fast vs. Accurate) compared to V5 ?
I will investigate the case where one of the objects fail. It should definitely not cancel the command for all the objects just because of that.
The fast/accurate setting has been removed - you will always get “accurate” now. We removed it because we did some testing and could not find a significant difference in speed between the two options.
