Hi, poking a stick at a gcode reader, to then represent the gcode as a curve… thats the easy part… literally 7 lines of code.
but— now I want to pipe it so its looks like the extruded filament it represents… a polyline (or nurbscurve or any curve) with 139000 points is just never going to pipe… so do I try reduce the points? break the curve into fix length segments? is there a trick where i can represent a curve with a thicker pixel thickness perhaps?
(of course in rhinoommon under code control)
