Redrawing DynamicDraw
I am trying to redraw a size change, but it will not redraw unless I move the mouse.
Is there any way to make it redraw at the moment I press it if I have assigned a key?
best
void KeybordEvent(int key)
   if (key == VK_A)
      A_key_pressed = true;
You need a reference to the document, then issue the following inside the KeyboardEvent handler:
RhinoDoc doc; // obtained elsewhere
doc.Views.Redraw();
Sorry, Some were missing.
What I mean is
   if (key == VK_A)
   doc.Views.Redraw();
I tried the same thing and it didn’t work, but when I defined it in RunCommand it worked fine.
Thank you so much.
What is the difference between this method and the other?
public delegate void KeyboardHookEvent(
	int key
