Redraw not cut when changing units / scale?
This is the first time I’ve seen this… could it be file-related? (6.18.19246.10001, 03-Sep-19)
hm… can you send me that file? It seems like we (they) should be able to track down the cause if we can see it happen.
Sent by PM…
Yep… here too - thanks. Does your command line say ‘updating settings’ for quite a long time? It was even slower here than your clip and I got bad object warnings…
https://mcneel.myjetbrains.com/youtrack/issue/RH-54652
Yep. I think that just stays until the command actually finishes. Bad objects - hmm, I must have had CheckNewObjects turned off… Turning it on, yes I get the bad object(s) created dialog popping up at the end. That’s actually typical when changing unit systems with these types of models I’ve found…
