Hello @karamba3d
I am trying to recursively add new supports to a floor plate with every analysis. So the idea is to check for max nodal displacement and add a support at that location and then reanalyze and repeat the process for a fixed number of iterations.
I am trying to script that in python with the help of all the example files published but to no success, obviously doing something wrong. Any guidance is appreciated Here is the code:
import clr
clr.AddReferenceToFileAndPath("C:\Program Files\Rhino 7\Plug-ins\Karamba\Karamba.gha")
clr.AddReferenceToFileAndPath("C:\Program Files\Rhino 7\Plug-ins\Karamba\KarambaCommon.dll")
import Karamba.Models.Model as Model
import Karamba.Results as Result
import Karamba.Algorithms as Algorithm
import Karamba.Nodes as Nodes
import Karamba.Supports as Support
import Karamba.GHopper.Models as GModel
import Rhino.Geometry as rg
out = Algorithm.ThIAnalyze.solve(model)
model = out[4]
node_count = model.nodes.Count
node_disp = Result.NodalDisp.solve(model,0)
max_disp_ind = 0
max_disp = node_disp[0][1].Length
for i in range (0,node_count-1):
disp = node_disp[0][i].Length
if max_disp < disp:
max_disp = disp
max_disp_ind = i
col = Support.Support(max_disp_ind)
model.supports.Add(col)
b = max_disp_ind
final = Algorithm.ThIAnalyze.solve(model)
z = final[4]
a = GModel.GH_Model(z)
Thanks in advance,
Pinaki
