Rectengular intersecion of two nurbs
Hey folks,
I would like to stretch one surface until it intersects another surface. The problem is that those planes have been cut so if I just try to stretch the surface it will follow the underlying control points which are wrong. The surface used to be a little round at the end so I cutted the round part of and now I have a gap between the cutted surface and another surface.
Is there a way to intersect those surfaces together with the condition that the angle of the surface doesn’t change? There should be just a rectangular intersection.
(surface1)…| (surface 2)
---------------- xxx|
the “xxx” shows how I want the surfaces to be stretched from side view.
I hope you understand my probem.
Thanks in advance. I’ll appreciate every answer!
Hi Bummel - can you please post a Rhino file with the objects?
thanks,
