Rectangular Point Grid - removed?
Quite new to Grasshopper, so now having a look into components. Has the Rectangular Point Grid been removed from the software? I see it mentioned in a learning material, but the only thing similar to it that I can create in Grasshopper by using only one component is the RecGrid - and that generates a grid of cells instead.
Curious if that exists or otherwise - what is your best/fastest way to create one?
No such component was removed. It may be part of a plug-in, not sure.
The RecGrid component does output points, it just doesn’t preview them. But you can connect the P output to a regular point parameter and they’ll show up.
So great to learn about GH with this online community. Always amazed at how quick it goes! Thank you @DavidRutten!
