Rectangular Array from both side
Dear My friends
I want to array these circle from both sides. (in x,y negative and positive direction)
please help me if you can.
Rectangular Array both side.gh (2.9 KB)
Rectangular Array both side.3dm (59.4 KB)
Like this?
Rectangular Array both side_re.gh (7.3 KB)
Thank you very much.
But you’ve created a new algorithm and i want to continue with rectangular array.
Is there any way ?
If you want it, why don’t you try to experiment with the function of Rectangular Array by yourself?
Rectangular Array both side_reV2.gh (17.5 KB)
yes, it works.
first: but I do not need a scale command!
can you set with no scale?
2nd: please look at the attachment.
I created a negative command and I could array in the X direction on both sides.
but when I want to set a negative command for Y direction we should change the REC 1 and create mirror one.
Now we have another problem with X-direction!
can we solve this problem?
Rectangular Array both side REV2 REC Problem.gh (7.9 KB)
We all use GH to do what is possible in the given function of the component.
If you are not satisfied with the function of some GH components, you can do what you want by coding yourself.
And looks like you don’t get gist of the definition I previously provided properly. Anyway the attached file is actually the same.
And remember to remove duplicate circles at the end. That’s why I provided you the definition without Rectangular Arrayin my first posting.
Rectangular Array both side REV2 REC Problem_re.gh (9.6 KB)
Thank you very much
we received to goal.
