Hi, Is there a way I can explode the rectangle into its 4 parts using C# rhino/Grasshopper?
Thanks
Thanks
You could turn the rectangle into a polyline and then access the polyline segments, which are four lines.
Thanks it worked
@diff-arch @Alca Does it work in GH Python? It did not work for me. But it gave 5 points. The code I wrote is placed below.
rect1 = rg.Rectangle3d(plane1, point1, point2)
polyline1 = rg.Rectangle3d.ToPolyline(rect1)
Thank in advance vijesh
That’s normal. A closed polyline, like your rectangle, is defined by a start and end point that are identical.
Thank you for your quick reply. I was expecting the segments. I have found the command.
polylineseg1 = rg.Polyline.GetSegments(polyline1)
polylineseg2 = polylineseg1[1]
I am finding it difficult to find any references, especially in GHPython. Are there any books for reference?
Thank you very much. vijesh
A polyline is like a list or an array of points, not a curve. Rhino.Geometry.Polyline.GetSegments()
simply constructs the collection of lines that connect the points for you. Previously these didn’t exist.
If you want a curve as output, you can do this:
a = polyline1.ToPolylineCurve()
There’s the documentation.
