Rectangle with random points, line by the middle |?
hi folks,
hi i am trying to generate a script as described in the tonic and on the attached sketch. but fail to implement the lines :frowning: i would appreciate a tip or help thanks in advance :slight_smile:
SKMBT_C20323041309030.pdf (221.5 KB)
Then post your script. Have you even tried? The rectangle with random points should be easy enough.
test.gh (8.4 KB)
this is how it looks, but how do I flip the lines so that they are not in the z-axis and how do I connect these to the points? thanks for the help
ROTATE.gh (9.7 KB)
wow, i really admire when you master grasshopper so well and can implement things immediately, hope i can do that once :slight_smile:
short question, is it possible to vary the lengths of the lines between certain values?
many many thanks for the super fast help
Add a random node to the Line Length input.
perfect, thank you so much Ftzuk :upside_down_face:
ROTATE lights.gh (16.2 KB)
i am speechless, exactly what i wished for, try right now to understand how it works. thank you once again :heart_eyes:
