Hello.
This is easy. I didn’t post code because it is simple, ‘how to draw a rectangle about the center of a point rather than from the corner’.
Thank you in advance.
Hello.
below is an example function which you can feed with a valid plane while providing the width and height of the rectangle. The center is the origin of the plane.
import Rhino
import scriptcontext
def DoSomething():
plane = rs.WorldXYPlane()
width, height = 20.0, 10.0
polyline = AddRectangleFromCenter(plane, width, height)
if polyline:
curve = polyline.ToNurbsCurve()
scriptcontext.doc.Objects.AddCurve(curve)
scriptcontext.doc.Views.Redraw()
def AddRectangleFromCenter(plane, width, height):
p0 = plane.PointAt( width * 0.5, height * 0.5 )
p1 = plane.PointAt(-width * 0.5, height * 0.5 )
p2 = plane.PointAt(-width * 0.5, -height * 0.5 )
p3 = plane.PointAt( width * 0.5, -height * 0.5 )
polyline = Rhino.Geometry.Polyline([p0, p1, p2, p3, p0])
if isinstance(polyline, Rhino.Geometry.Polyline):
if polyline.IsValid:
return polyline
DoSomething()
c.
Thank you @Clement .
This works and is helpful and could be applied to a grid; however, I wonder if there is a simpler method without drawing polylines. In GH, I simply ‘construct domain’ and divide the x and y inputs by ‘x/2’ and ‘-x/2’ respectively.
I have been trying to add this line of thinking to python, but it might not work.
Thanks!
@brobes05, yes indeed, you can simplify the function further and draw a Rectangle3d
instead of a polyline using just two points divided by 2:
import Rhino
def DoSomething():
rc = AddRectangleFromCenter(plane, width, height)
if rc:
curve = rc.ToNurbsCurve()
a = plane.PointAt(-width * 0.5, -height * 0.5 )
b = plane.PointAt( width * 0.5, height * 0.5 )
rectangle = Rhino.Geometry.Rectangle3d(plane, a, b)
if isinstance(rectangle, Rhino.Geometry.Rectangle3d):
if rectangle.IsValid:
return rectangle
DoSomething()
The reason why i prefer the first function is the rectangle.IsValid
part. It seems that a Rectangle3d
is valid, even if the width or height is zero.
c.
