Rectangle command does not Shift + Osnap
Sometimes I want to place rectangular (rounded too) panels in places, but using [Osnap + Shift] does not permit me to place, say, the centre point “Between” anything.
This is very annoying, as I have to create points first, when the rectangle command should be able to do this directly, as all I am doing is placing an initial point regadless of the creation method.
Can this be fixed in Rhino 8 please?
Hi David -
That seems to be working fine here and your image shows that “Between” is available.
Can you perhaps provide more details?
Hi Wim.
Okay, that is odd. It wouldn’t let me select when greyed out. But now I try the same thing:
Look how the selection is White text now I can chose. :slight_smile:
