I quite often want to indicate the width of an object by just clicking on reference points to set the width and then individually click for the height but there’s this weird thing that happens which I consider a bug.
So let’s say I have this scenario where I have 2 objects and I want to draw a rectangle between them but I want to specify the height by typing it in and I don’t know the distance between the objects.
Something like this:So I use the rectangle tool and click on this point as a reference:
Then I want to click on the point on the other side to indicate the length:
But as soon as I click, the rectangle flips the other direction.
I know there’s workarounds to this problem. Like I can move the object afterwards to the right location, and I could start the rectangle on the left side and then clicking on the right side but sometimes that’s not possible either.
I’m aware that this is a minor thing, but it also seems like a quick fix? If length value is negative, draw rectangle in negative direction?
