Say you have assigned C as an alias for Copy, or AL for ArrayLinear,
Record History will not work when using C or AL, but it will work as expected when using the actual commands Copy or ArrayLinear.
This happens also when Record History is used once or always.
Gijs
(Gijs de Zwart)
January 6, 2025, 1:28pm
2
I don’t see that here. pls run _SystemInfo and post back the results.
Hi @Gijs ,
Very strange behavior
I captured screen C vs Copy. SystemInfo below;
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15001, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Commercial, build 2024-12-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.16
Primary display: AMD Radeon 780M Graphics (AMD) Memory: 1GB, Driver date: 8-13-2024 (M-D-Y).
> Integrated accelerated graphics device with 5 adapter port(s)
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 2-22-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.80
- Secondary monitor is laptop's integrated screen or built-in port
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-22-2024
Driver Version: 31.0.15.4680
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll "Enscape.Rhino8.Plugin" 4.1.1.35
C:\Users\bogda\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\\D5Conv.rhp "D5 Live Sync for Rhino"
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp "Rhino Labs Tools"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.14.24345.15001
C:\Users\bogda\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp "PanelingTools"
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
Gijs
(Gijs de Zwart)
January 6, 2025, 2:24pm
4
I see, order seems of influence, I’ll log a bug
In the first video I try C first and Copy second,
In the second video I try Copy first and C second.
Gijs
(Gijs de Zwart)
January 6, 2025, 2:34pm
7
RH-85379 History record fails
Gijs
(Gijs de Zwart)
January 6, 2025, 2:35pm
8
I only see it with one shot
I cannot replicate it with Always On… maybe I got confused…
P.S. If I may the Record History button could maybe use an improvement, to let the user turn it on and off by clicking it, instead of it automatically switching off.
Current way of choosing between one shot and always on is counterintuitive. Best would be a simple ON/OFF button…
Gijs
(Gijs de Zwart)
January 6, 2025, 4:15pm
11
that is how it currently works. If no command is running, it is a On/Off switch. If a command is running it is a single shot on/off switch
brian
(Brian Gillespie)
January 14, 2025, 10:19pm
12
