Record History broken when clone so undo yet remains now broken
I am not a normal user of Record History, as inevitably it gets broken.
I have just thought sensibly to use it on laying text along a path.
I set record running, select the text (made with text tool and its grouped and contours)
run flow command, select the line option, and select rhs end then lhs end of line (I had drawn earlier),
select the target curve, and hey presto its where I want it outward of the circle. (having done my maths and worked out the spacing of line to text and tha gap it had to fit in !..as there is no leading adjustment)
I fancy a variation of the colour to show someone, select the entire artwork, copy it 200mm to right,
get warning broken history,
so undo that move and copy, but now the text doesnt change if I alter its scaling, when before it did.
surely undoing the copy and move should see me good ?
Steve
hard to diagnose without a fileā€¦ any chance you could share one, or crate an example that shows the problem?
