I am trying to repair a mesh with local artifacts. The artifacts appear as small “pockets” or folded mesh regions. So far i can detect these regions quite reliable.
My current workflow is:
1: Detect problematic regions using mesh ray intersections
2: Identify the corresponding mesh faces
3: Expand the detected region by including neighboring faces (currently using a custom Python script)
4: Delete the faces
This works surprisingly well and removes the unwanted pocket geometry. The challenge is reconstructing the missing area. For one mesh i can reconstruct the area by extracting the naked edge loop and triangulating them
for others it doesn’t work…
After some debugging I found that:
The problematic naked edge loop is closed
The loop contains several self-intersections
Rhino reports multiple curve self-intersection points
I tried shattering the curve at the self-intersection locations and rejoining the resulting segments, but I still cannot generate a valid triangulation for that region
Rhino’s “Fill Mesh Holes” command closes some holes successfully but leaves this particular region open
repair_mesh_fold.gh (972.2 KB)
Any suggestions how i can close the mesh would be greatly appreciated.
Thanks
