Is there a way I can reconstruct the contour lines (like draw a new line over it or something) so I will get just 10 points on the line in the full length of the shape? reconstruct line.gh (454.5 KB) Thanks in advance.
I don’t understand what you try to achieve. right now you get a contour line for every brick height.
Yes but as you can see with divide curve there are a bunch of lines that aren’t over the whole length
The first circle is the right amount but the circles below are seperate lines. And it is indeed to make a brick pattern.And do you want some kind of stack bond (stapelverband)?
More like a stretching bond
This is no stretching bond, but as a basis for the division: reconstruct line ME.gh (455.1 KB)
Thanks alot! It think I can work with this
