Hello
Can i get some help with this project?
I need to build a reprocal structure, now using ngon
I cannot seen to get the correct joint between the rectangular elements
I am using region slits, but after applying it´s thickness, i do not the correct difference angle.
Any ideas?
RE2.3dm (112.6 KB)
RE2.gh (26.8 KB)
Thank you Joseph, i will check that out
Because region slits will not give you true notches, only rectangular ones. If true slits are needed, then you need to make them.
Also, it’s best if you post a screenshot of the problem.
Hello Rene
Thanks for your reply.
What you described is exactly what is going on
You can see in the see in the image that the notches do not align
Could you hel me how to generate them?
Best
Did you try using Box Slits instead?
the image is using regions slits
Sorry, I just corrected the question: I meant BOX slits!
*Also, some people might not have the plug-ins you’re using, so I recommend you internalize the objects in question, using a geometry or data component:
Another route to explore (searching the form) is “waffle” structures.
https://discourse.mcneel.com/search?expanded=true&q=waffle%20%40Joseph_Oster%20order%3Alatest
They emphasize the slots to connect pieces rather than reciprocal structures but you might find some inspiration?
(click the image to see it full size)
Thank you Rene and Joseph
Box slits dis the job (i had to convert breps to boxes to do that)
Now i have to figure out how to mill this on a 3 axis cnc router machine!
