Recently used commands functionality
Over here, a trainee asked me about the ‘recently used commands’ functionality when I click the right mouse button in the command bar.
1- Is it possible to activate this list with the keyboard instead of clicking the mouse?
2- I also discovered the ‘recently used’ toolbar. However it doesn’t seem to show all commands when I have used them. For example the ‘loft’ command doesn’t show. Why is that?
-_Popuptoolbar “Recently Used” assigned to a key should do that.
No idea why Loft is not being added, any others you found?
Thank you very much for your prompt reply Gijs.
1- _Popuptoolbar “Recently Used” works perfect. I’ll make the trainee happy with this.
2- You’d better ask which commands do work in the recent toolbar.
Some commands that obviously don’t work are:
  • _CurvatureGraph
  • _CurvatureAnalysis
  • _Pull
  • _Contour
  • _Section
  • _Scale1D
  • _Shear
  • _etc
  • _etc
It looks the recently used toolbar only gets filled when pressing buttons.
Very clever of you!
You’re right, that’s apparently the case.
However, do we consider this functional behavior?
Who developed this and what were the considerations?
I’ve logged the issue as RH-94557 MRU: also add typed commands if there is an icon.
