Hi. I am trying to ‘clean’ a model that I have in order to export it (through MOI) to Modo and Uvmap it. I believe that is not possible in Rhino for Mac.
I have been learning a lot from the forum regarding how to make ‘proper surfaces’.
This is an extract from my main model before:
As you can see there are a lot of isocurves and also they do not match with the construction of the next surface.
I would like to have single-span surfaces and also to keep the iso-curve structure equal in each strip (surface).
In order to do that I decided to rebuild each strip with cleaner curve and add more support profile curves to my rials:
I checked the continuity (GCON command) and they seem to be right (G1 is what I want). I ran the Zebra and it also looks quite ok. Still When I join all my surfaces (which share the profiles and the rials are G1 continuous) I can see an anomaly on the surface:
I have notices that If I do it at once with my 2 rials and all my profile curves it makes it continues…but the iso-curves are a little bit messy.
Please find the file here :
Rebuild_Forum.3dm (93.8 KB)
Thanks so much for helping me always
Edit: I manage to find the solution with matchsrf. What I do not understand if why I need to match it if all the surfaces are coming from continuous curves.
