Rebuilding polygons at scale
Hi All,
I have a large number of GIS extracted building footprints that are made up of a lot of points. When I extrude them for perspective images they look messy. Is there a quicker way than manually tracing over them to rebuild the polygons into a simpler but relatively accurate version, as I’ve shown in the image? I am decent in GH if that is required.
Hi Banjo -
In the Rhino 9 WIP, you can use the ElmoPy test command to achieve this.
Thanks Wim, currently using Rhino 7, so might need to look at upgrading
