I Thought I could rebuild it as a degree 4 curve. I have 5 control points summing the two curves.
The thing is when I try to draw a curve (following the control points) it does not match with the curve I want.
I used the ExtractPT in order to recreate the two curves as one with degree 4 .
You can not have a single span curve, such as degree 4 with 5 control points, which is straight for part of it’s length and curved for the other part. That’s fundamental limitation of single span NURBS curves. You will need at least two spans.
Is it because some folks say only single span curves and surfaces should be used for “Class A” surfaces? If so it is important to understand that the same folks usually use multiple single span curves and surfaces where needed. And a curved segment connected to a straight segment is an example of where multiple single span curves or a single multi-span curves are needed.
I want simple span curves cause I need to export the model to Modo through MOI. I already did the model without taking care the building on the surfaces. It looks crazy when exported to polygons. Now I made a tryout with the rebuilding of surfaces neatly. The model looks super clean in modo now. I am trying to continue that process. Its truth what you say. the problem that I have is that in some parts of my model my rials are discontinuous.
I think that is the reason I can not continue to do the super neat process. You can see in this prntscreen. My rials are coming from a fillet edged cube. The part where the rials touch the corner its when becomes a little bit messy:
As you said this is the best way I could manage it so far. I am not sure what will happen in modo when this gets to polygons. I will have a denser mesh where the ‘patch’ is.
