Is there a way to rebuild a solid so it has less complicated surfaces. I have a solid made of too many faces imho but i only see the option to rebuild surfaces which will take forever. Is there a way to easily simplify my solid?
Hi
Under the solid edit tool bar there is merge all faces command. That should do the trick.
I tried it but its saying cannot merge any further but thing is autocad has a feature to automatically convert closed meshes to surfaces which works really well but somehow i think it can be much better
I tried it but it kept saying cannot be merged further, anything else?
You should post a picture and/or a 3dm file of your solid.
Otherwise it is really difficult to help you.
Norbert
