Is there a way to use the rebuild command such that corners are preserved? I’m getting a lot of material with very, very heavy point counts and I’d like to simplify the curves without losing all the sharp corners.
Thanks in advance for any advice you’ve got.
Hello - I guess, pre-select, then
! Explode Rebuild Pause Join
if all the curve segments can be rebuilt to the same settings… If the curve does not Explode, include a
SimplifyCrv
as well.
FitCrv might also work for you, it has an angle threshold setting to preserve sharp corners of smaller than a given value.
–Mitch
