Rebuild WIP: Point Count can be set too low for degree in Tolerance mode
Rebuild WIP: In “Rebuild to tolerance” mode the “Min Point Count” and “Max Point Count” can be set to value less than the minimum number of points for the specified degree.
Work In Progress
(9.0.26097.12305, 2026-04-07)
When non-valid for the degree point count is used the resulting curve has the same point count as the previous use of Rebuild.
If you switch to “point count” mode from “tolerance” mode with the Min Point Count too low the the Degree does not update based on the Point Count. The result uses the degree allowed by the Point Count.
thanks @davidcockey
RH-94684 Rebuild: invalid values are possible
RH-94684 is fixed in Rhino WIP
