Rebuild (Curve) Checkbox for showing control points
Hi @hannesgrebinwork what would that solve for you?
You can turn on the control points for the curves and then run the command, which will show the points as well as the rebuild curve points. Is that what you would like to see?
Ahh yes, totally obvious. But would be nice as a normal feature esp when running the command. Otherwise there is no visual control and most of all feedback.
