I would like to report that on the last release whenever i run the rebuild command Rhino crashes with the ntdll.dll error (event id: 1000). Same in safe mode.
Also, just to mention that Rhino was occasionally crashing at startup before this.
After a crash, there was window popping up where I could send the report but it is not always shown. Is there any location where I can pick crash logs and send them manually to Mcneel?
Hi - these are created on the desktop but only when the crash dialog pops up, and only for the duration that this dialog is up. That is, when you close the dialog, the file on the desktop is deleted.
