antho2b
September 18, 2018, 7:56am
1
Hi !
I want to rebuild arc with a new diameter, so I did this little tool :
arc.gh (13.6 KB)
arcs-2pt.3dm (798.1 KB)
I collect the original radius and find a new one on a list using “find closest point”, it’s maybe a little bit tricky, but it work.
My real problem is :
How can I rebuilt arcs using start and end point and the radius (like with the basic rhino tool “Arc” start, end , radius)…
any help will be apprecied !! thanks
make sure to internalize your data so you dont need an extra 3dm file.
i simply joined the curves & fetched their mid points.
arc_re.gh (21.6 KB)
antho2b
September 18, 2018, 8:35am
4
thanks for helping guys but both of your solution only allow me to rebuilt the same arc with the same radius
waht I want is to apply the new radius to a new arc using the same end point and start point that the old one was using…
antho2b
September 18, 2018, 9:22am
6
Thank you very much HS_Kim
I did try to merge your tool with mine recalculating the arc angle… but at the end the diameter didi not correspond
It’s a tool to allow me to creat rounded and standard value to bend tube.
So i want the final radius of the new arc to be equal to the desired radius…
arc-02.gh (22.0 KB)
