Any hint to get node values?
<P id= "7">6715845.982000 25498179.228000 70.484000</P>
so this is one point ? and you want
x = 6715845.982000
y = 25498179.228000
z = 70.484000
please upload your file - it s impossible to help from a screenshot.
Aim is to write script to have XML file converted into mesh. I tried through pancake plugin with Gh basic components but it was very slow with large xml files.
test.zip (18.8 MB)
test.gh (7.6 KB)
unzipping your 19MB zip will result in a 83MB xml.
That s no fun to look at or to play with.
ok so basically you want to read mesh / Terrain Data from a BIM file… (?)
Did you research if there isn t any plug-in that can do the job ?
Do you really need this functionality that often / need more performance that it s worth implementing it ?
I really recommend to check existing solutions and do not reinvent the wheel.
If you do your own implementation:
- create / get a very small sample file (max 500 nodes) - this is much easier to debug
- get a cascade of file-Size 1 - 2 - 4 - 10 - 20 - 50 - 100 MB for performance testing
- check some basic xml tutorials
- read the documentation of the xml file to make sure you cover all possible information (nodes / tags / attributes)
- ask chat gpt and ask / prompt bottom up…
do you really need VB ? C# or phyton are more common in the Rhino-Community I think.
If it s a professional context, ask somebody who can code/program and pay that person.
would be nice to post a working code / gh definition / solution - so others that find this topic do not end up in looking at (nearly useless) screenshots.
Good point. Here is the code needed to access nodes of xml file:
Dim xmlDoc As New XmlDocument()
xmlDoc.Load(FilePath)
’ Check whether parse string contains data
If xmlDoc Is Nothing Then
A=“XML document not loaded.”
Else
A=“XML loaded successfully.”
End If
’ Create new namespace manager
Dim defaultNamespace As String = xmlDoc.DocumentElement.NamespaceURI
Dim nsManager As New XmlNamespaceManager(xmlDoc.NameTable)
nsManager.AddNamespace(“ns”, defaultNamespace)
’ Start accessing nodes (Read xmldocumentation for more help)…
