Can I read the layers from a Rhino file on disk that I have not open? It doesn’t appear that any of the components like geometry pipeline, Human’s Layer table, Elefront reference by layer, etc. can do this.
Ideally, I want to just read a file so I can write specific layers to a Revit family file. So opening each document would be a bit too cumbersome to process, because I may need to update the files at a later stage.
Hi @Intuos the v5 version of eleFront for R7 allows you to reference from external files. Using “insert parameter” you can add a file path or file paths.
The context menu also allows you to bring the the geometry as “Ghost Geometry”, which allows you to bring in a lot of stuff but keep your memory footprint down
