Like check this out, the same elements but a different parameter:
Would you be able to share a revit file with just couple of doors/elements to have a look at?
sure, this is not a door, but a simple generic model family. Hereâs a sample file with a few family instances:
TestFile.rvt (5.6 MB)
Japhy was referring to a curtain wall door panel in his example. I suppose âHeightâ in particular, as well as a few other system parameters would probably cause such trouble
Ok I see the issue now when the family has the instance parameter with the same name as well⌠only work around I see for now for you to continue work is the boolean ReadOnly we mentioned before and the inspect element indeed.
It is weird how âElement Parameterâ is not showing both or the correct one.
Maybe @Japhy and @kike would be able to see if it is an issue to be resolved
Indeed, thx!
If i recall we used to give a warning there, âHeightâ is ambiguous, please use Query Element Parameters or something like that.
We prioritize the BuiltInParameter return first.
This might be a case of providing too much, but erroring on that side IMO is better than restricting the user.
Yeah, but I still donât get where that BuiltInParameter is coming from, as this element for example clearly only has one Height and its the instance. The other one is also not visible through the API
Hi @Danail,
When a text is converted to a parameter-key RiR search all BuiltInParameter
that are called like this.
And then use some logic to decide in case of conflict.
This Element has the BuiltInParameter.CURTAIN_WALL_PANELS_HEIGHT
(-1010300) defined.
This code returns an instance of a ARDB.Parameter
and shows the assert message even the parameter is not visible on the UI.
var parameter = element.get_Parameter(BuiltInParameter.CURTAIN_WALL_PANELS_HEIGHT);
Debug.Assert(parameter == null);
Iâm going to update this logic to give priority to those parameters that do have a value over those that do not.
public static Parameter GetParameter(this Element element, string name, ParameterClass set)
return element.GetParameters(name, set).
OrderByDescending(x => x.HasValue). // Order descending by HasValue to give priority to parameters that do have a value.
ThenByDescending(x => x.Id.IsBuiltInId()). // Then by IsBuiltInId to give priority to built-in parameters.
ThenBy(x => x.IsReadOnly). // Then by IsReadOnly to give priority non read-only parameters.
ThenByDescending // Then by storage-type to give priority ElementId parameters over String ones.
x => x.Id.TryGetBuiltInParameter(out var bip) ?
x.Element.Document.get_TypeOfStorage(bip) :
StorageType.None
FirstOrDefault();
This should be enough to return the family instance parameter in case it is defined and conflicts with a built-in one that do not have value.
Thatâs great! Iâm not sure this will help and I havenât tested it for a curtain wall panel family instance, but for my Generic Model family, I have tried it like that:
and it worked fine. Simply Element.Parameters, then you circle through the set. Iâm not sure it will be the same for Curtain Wall panel, but it should be as the ânon-existingâ heightâs ID is the same. I will check though
I believe thatâs what Element.Parameters method is for:
It already gets rid of the unwanted ones. It should probably simplify things. Not sure though⌠just a suggestion, Iâve already submitted enough spam in this topic anyway
Element.Parameters
give you a curated list of parameters, but not all the available parameters under an Element.
For instance this one is not available in Element.Parameters
but is always there. There are others.
var param = element.get_Parameter(ARDB.BuiltInParameter.ID_PARAM)
The goal of âQuery Element Parametersâ is give them all.
An other way of giving priority to those visible parameters over the more obscure ones may be check if they are contained in the Element.Parameters
set, but is not the fastest property ever, because it has to iterate over all the parameters on the element and build a set. It seems too much just to test if one is contained.
For this situation Revit API provides Element.LookupParameter(string name)
but the documentation reads like this.
This method will attempt to find a parameter on this Element whose name matches the input. The possible results include:
- A single matching parameter is found: it will be returned.
- No matching parameter is found: null is returned.
- Multiple matching parameters exist. In this situation the first one encountered will be returned. This match is determined at random and may change in the futureâŚ
The word ârandomâ and âmay change in the futureâ in the description are the reasons that made me avoid calling it and do my own.
Anyway, thanks for all you research on this topic.
