Read File component error
Yesterday I updated to the new Windows 11 beta, today I’m getting the following error on a Read File component:
  1. Before Solution exception:Method not found: ‘Microsoft.CodeAnalysis.SyntaxTree Microsoft.CodeAnalysis.VisualBasic.VisualBasicSyntaxTree.ParseText(System.String, Microsoft.CodeAnalysis.VisualBasic.VisualBasicParseOptions, System.String, System.Text.Encoding, System.Collections.Immutable.ImmutableDictionary`2<System.String,Microsoft.CodeAnalysis.ReportDiagnostic>, System.Threading.CancellationToken)’.
  2. There is no valid parser available.
Rhino 8 SR4 2024-1-30 (Rhino 8, 8.4.24030.15001, Git hash:master @ 97577baf4e4ae40c7f2ed3ef4e802db24f2e82ae)
License type: Commercial, build 2024-01-30
License details: Cloud Zoo
Windows 11 (10.0.22635 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9181.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\armat\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Cyberstrak\R8\CS_ModelingPlugIn.rhp “Cyberstrak Modeling PlugIn”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\import_STL.rhp “STL Import”
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24030.15001
Is that a brand new Read File component, or is that error you get when trying to read a file?
It’s the error I get when trying to read a file. The same script worked yesterday, no changes.
I have the same issue. Was also working fine yesterday.
Rhino 8 SR4 2024-1-9 (Rhino 8, 8.4.24009.13521, Git hash:master @ 92a8f2048b418ceab8c8de06a88b7939594e09f2)
License type: Evaluation, build 2024-01-09
Expires on: 2024-02-05
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 192GB)
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 12-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.33
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 7-24-2023 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 12-6-2023
Driver Version: 31.0.15.4633
Total Video Memory: 24564 MB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.2.0
C:\Users\Primoz\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\Primoz\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.5\Substance.Win.rhp “SubstanceImporter” 2.0.5.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24009.13521
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\export_ACAD.rhp “AutoCAD file export : export_ACAD”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24009.13521
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24009.13521
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24009.13521
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.4.24009.13521
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24009.13521
C:\Program Files\Rhino 8\Plug-ins\MeshTools.rhp “MeshTools”
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.4.24009.13521
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24009.13521
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24009.13521
C:\Program Files\Rhino 8\Plug-ins\import_OBJ.rhp “Import_OBJ” 8.4.24009.13521
Also switched to Win11 since yesterday?
There was an update, but i was already using Win11 before.
I should clarify: I was already using Windows 11 Beta, and yesterday there was an update to the beta.
Thanks for the info. I don’t have Win11 myself, but I’m going to find someone else at mcneel who does and who can figure this out.
Many thanks @DavidRutten
I found this workaround to tide us over:
@DavidRutten I just wanted to let you know that this seems to have sorted itself out this morning.
Oddly, I’m not seeing an update to either Rhino or Windows.
FYI, I also had a C# script that was also giving me errors starting last week, and now it has also self-healed.
