This is very nice! What 3d printer did you use to print it?
@martynjhogg Sorry for the late reply. Yes, as @laurent_delrieu said, the printed pieces in the picture are not mine.
Thank you @laurent_delrieu! I got the reaction diffusion values from your plugin.
And for everyone who is interested, this is the GH file.
It contains plugins.
Dendro for meshing. Weaverbird for dual of triangles. Nautilus for reaction diffusion on mesh.
reaction lamp v1.gh (214.0 KB)
Hello @Quan_Li cool to see your implementation. Mine is a little different. Many logics can be combined.
Sphere is using Icosahedron mesh, but your way is a more modular.
For the direction I use a special component that uses curves.
The dots are done using the dual or reaction diffusion dot from “low” resolution mesh. To smooth values I use the trick to subdivide mesh with my Nautilus components then smooth values a bit.
For the holes I try to bump more or less the dots. Not very nice solution, must be surely tweaked.
reaction lamp delrieu.gh (33.2 KB)
