RE: Windows/roof lights Optimisation
Hello, please I need a method or relationship between changing the dimensions of the classroom and the dimensions of the window while increasing the number of dogs in the classroom within the rhino program.
Hi -
If you can describe the relationship in words, it should be possible to do this in Grasshopper.
The window area is 15% of the classroom area
So that the dimensions of the classroom are increased so that it does not reach a square shape, we fix the length and control the width, knowing that the dimensions of the classroom are 7 *5 and that the window is 15% of the classroom area, provided that it is divided into sections, and the center of each window is fixed, and Without changing the height of the window and we must leave a distance between the tables of 60 cm.
Continuing the discussion from RE: Windows/roof lights Optimisation:
1.pdf (74.8 KB)
2.pdf (78.4 KB)
3.pdf (78.0 KB)
4.pdf (76.7 KB)
5.pdf (78.0 KB)
