I’m trying trying to re-order two different point flows into the same list order as the original list.
Thanks!
Thanks!
Use Weave.
I’m not sure what you mean by using weave, how would I go about incorporating that into my point lists?
How does it know to return the points to their original indices?
Use the same dispatch pattern for the weave pattern.
Ah I see. Thanks!
Ok so I tried it. The problem is that I need to reference the points as they were before I dispatched them into two separate patterns.
Nevermind it worked! I just needed to swap the 0 and 1 inputs. Thanks alot!
