RDK problem in Print
ı am using rhino7 for a certain period of time ı cant use print.when ı try rdk is problem can you help me ı guess we should solve plug ins
Hi Naz -
Please provide both an image of the error message that you get and the output from the Rhino SystemInfo command.
Sometimes there is no warning but I still cannot print, and when I do, it appears as a white page like this
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Educational Lab License, build 2024-04-16
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Unplugged [95% battery remaining] ~77 minutes left
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-13-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-30-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.30
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-30-2023
Driver Version: 31.0.15.4630
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
Hi Naz -
Printing to PDF is very much related to the display. Please open the Notifications panel in Rhino and follow the links to the latest drivers for your GPU.
Apart from that, I see that you are using “Microsoft Print to PDF”. For support with that printer driver you’d need to contact Microsoft as we have no way of controlling what goes on in there. I’d recommend to use the “Rhino PDF” printer instead.
I didn’t quite understand what you said but I noticed something.
When I select the objects and do ctrl+p, they appear and I can print successfully, but nothing appears without selecting. Is this a setting? How can ı fix that?
Hi Naz -
Yes.
It solved thank you so much.
