Razer Core and Vray Next
Is there anyone using Rhino 6 with Vray Next on a Razer Blade laptop, with a Razer Core GPU attached to it? If yes, do you see Vray using the full power of the additional GPUs? Thanks in advance.
Luca
Hello, Luca,
Be advised V-Ray Next supports only Maxwell-, Pascal-, Volta- and Turing-based NVIDIA GPUs.
Тo use NVLINK on supported hardware, NVLINK devices must be set to TCC mode. This is recommended for Pascal, Volta and Turning-based Quadro models. For GeForce RTX cards, a SLI setup is sufficient.
If you have any trouble with the utilization of your hardware when using the V-Ray GPU engine, please reach out to support@chaosgroup.com for assistance.
Kind regards,
Peter Chaushev
V-Ray for Rhino QA Specialist
www.chaosgroup.com
Hello Peter,
Many thanks for your help.
Luca
