Raytracing keeps restarting
Hi all,
I am trying to preview some grasshopper items using Raytraced mode. Although it does work (I select materials in .gh and the materials are correct in the viewport) the raytracing engine is constantly resetting/restarting after 1 second.
What am I doing wrong?
tx,
dh
Hi Declan -
I internalized a simple box, added the default Create Material and the Custom Preview component and am not seeing the Raytraced viewport being reset.
Are you doing something differently?
Thank Wim!
EDIT
I found the issue. There was a 1 second trigger delay hidden in the definition, which was causing the viewport to refresh. Thanks for the support!
So everything was working as defined by the GH script :slight_smile:
Yep! The error was between the chair and the keyboard!
