So I am trying to export a page with three different display types (wireframe, arctic and raytraced) directly into jpeg (as exporting to PDF makes the software freeze).
In the exported picture, the raytraced image is missing some shadows compared to the version displayed in Rhino
In Rhino, raytracing is not always compatible with modeling and drafting.
The Raytraced display mode does not work when printing details on layouts. The result will be as with the Rendered display mode.
→ RH-50153 Raytraced in Layout and print does not work
If you need raytraced output on that layout, you can use a picture of a viewport in Raytraced on the layout.
Actually I ended up doing something way less intelligent which was simply making a screenshot of the raytraced bit and photoshopping it into the final picture
