Raytraced in viewport far too rough
I get this in the viewport:
When I hit Render, I get what’s expected:
Veiled_Virgin.7z (6.5 MB)
Charles please provide SystemInfo.
Ok:
Rhino 9 SR0 2026-9-15 (Rhino 9 BETA, 9.0.26258.12303, Git hash:master @ c3d10428b087d6fe48c7db5ecea508f0cce7a6e5)
License type: Commercial, Build 2026-09-15
License details: Cloud Zoo
Expires on: 2026-10-30
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.12
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 1-20-2026 (M-D-Y). DirectX(11)
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26258.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26258.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26258.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26258.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26258.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26258.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
I now see the effect is with a simple cube as well:
It seems to be working fine on my end. I’ve sent the download link for the latest Rhino BETA. Could you pls give it a try when you have a moment? Thank you.
No luck.
Same in BETA (9.0.26265.18303, 22.09.2026).
Please check whether the Viewport resolution sharpness option has been adjusted. If it has, please restore it to the default setting - Pixel perfect.
Works now, thank you.
I’m sure that I never touched the Viewport resolution sharpness option.
I reinstalled the latest Rhino BETA both on my laptop and desktop. I can’t reproduce the issue you mentioned. BTW, this model seems quite suitable for demoestrating Subsurface-type material; even with simple settings, it cae render pretty good results. Thank you again for sharing the model.
That’s what I wanted to play with as well.
Not mine, it’s from here:
