Something more for you to iron out:
Raytracing far from origin isn’t behaving correctly.
Close to origin it works fine.
But noise reduction causes a strange blur bannering for a while before it starts working. Once the first noicecanselling is done the rest of the rendering updates nicely.
Manipulating the view is very slow since the startup resolution is too high and Rhino jumps in and out of Raytraced and rendered mode, showing that I zoom in in Rendered, then switching back to raytraced that isn’t zoomed in yet and then zoom that in, so manipulating the view is very trippy.
And clicking on options while a view is in raytraced mode makes everything slow. So right now raytraced mode is still a “fun” display mode that isn’t suitable for using while working. Raytraced should always work in the background and not affect foreground processes IMO. Moving an objects should be instantaneous in all other views and then raytraced should update whenever it can.
I am sad to say that there is issues here that does not make this feel like the third generation of a raytraced display mode, but rather like a partly integrated first iteration of the technology.
On my system when it has ran for a while when I manipulate a view it does not show frame 1, frame 1, frame 1, but rather wait to redraw until frame 4 is calculated. That makes it laggy. Then it waits for frame 40 to be completed. Kind of taking “realtime” out of “realtime rendering”…
If I alter the reflectivity of a material it takes six seconds before it updates…
My main focus would be:
1- Make Raytraced wait for manipulations of objects instead of forcing manipulation of objects to wait for raytraced.
2- Dynamically de-resolution when manipulating so we don’t need to rely on rendered mode, OR switch fully to rendered mode for manipulation until the stuff works.
3 - Fix the strange wait issue, manipulating a material is a pain right now.
3- Fix the view redraw issue so raytraced doesn’t toggle back on until it has figured out what the last camera position from “rendered mode fast display toggle” was. This will fix the trippy zoom-in-out issue.
32GB ram, i7 processor, 56 meshes in file, no bad objects.
Rendering on 4070 ti.
