Is there a summary (or detailed information) on the implementation for rayshoot, shootray, and onshoot? Below is what I think I have found, please update or correct me:
From what I can find; rayshoot is in rhinocommon, shootray is rhinoscriptsyntax, and onshoot is the opennurbs.
rayshoot takes a geometrybase and shootray takes an array. Is shootray just calling rayshoot and doing the geometry conversion? Is this written in C++ or is there a cost to running rayshoot in a loop that would be higher than shootray?
onshoot is similar in functionality to rayshoot, but is through the opennurbs and not rhinocommon. Is there a difference in how the calculation is performed/ how the geometry is compared?
Is there another c++ sdk version, or is this the line->mesh/surface intersection?
Are all of these at the lowest level a line with a length the size of the model and doing a line/object intersection, or is there some other implementation method?
Thank you
