I wonder what opportunities and limitations would arise if one attempts to use Raven AI to deploy Va in a parametric design situation.
@djhg We are exploring the compatibility between VisualARQ and Raven. The first impression is they work well! Just need to specify to Raven that when you try to do something, use the VisualARQ objects instead of extrusions, polysurfaces or other geometry. The timing to work with VisualARQ object components seems to be higher than with primitive geometry though.
We need to explore this a bit further.
I encourage you to try it out and share your experience!
