All done in Rhino 6, Keyshot render
Regards to all
nice, as a suggestion. you should avoid making surfaces from trimmed ones like you did in the upper areas windshield and windos for example. if you work as you did in the side of the vehicle you will have cleaner and in most cases, smoother results. think in the main or macro shape to make the base surfaces, then you work on the details.
Thank you for the suggestion. Yes, the windows were made fast and without “care” to make them single span, as that did not seem to interfere in the renders.
Regards
