Ratchet gear
I’m trying to make a ratchet gear in grasshopper where I can define the number of teeth and radius of the circle on which those teeth are going to sit on.
-I use a flow component to put the teeth on the circle. I set stretch as false because I want to keep control over the initial geometry.
-The teeth is a geometry I reference from the rhino file that I array
-In order for the flow to work with the array without using a stretch I first scale the array to fit the length of the target circle. (the scale factor is the ration between the length of the array and the circle circumference)
It all works relatively fine, except that there is always a tiny gap between each teeth. Any idea what the issue could be here?
260608Gears F.gh (11.3 KB)
Alternative.
Another alternative - after moving your geometry to the origin:
260608Gears F-bb1.gh (11.0 KB)
Leopoldomonzani, I’ll try that thanks
Birk Binnard, no gap but with the stretch on, which deforms my initial geometry…
To avoid deformation.
260608Gears F a.gh (19.7 KB)
260608Gears F b.gh (20.8 KB)
