Rank points
Hi I would like to know if it is possible to change the rank of points in a list.
I want the list to begin with the lowest X component and finish with the largest.
I want the first panel (picture) to have similiar rank as the second panel (panel below the first one)
Hi Azit,
You need to deconstruct (deconstruct point) your point and then you can sort (sort list) your point based on the X value.
You can just use the Sort Points Component
Found here:
Vector> Points> Sort Points
Note this works here as you want the X Coordinate sorted, if you want Y or Z its a different workflow.
Thank you so much! it helped! :slight_smile:
thank you !
