Randomly rotating each item inside repeated panels (LunchBox + Orient)
Hello. I am new to grasshopper and looking for some help.
I’m an architecture student working on a facade and I’m not sure how to move forward with the randomization.
What I have:
  • A 2x2 matrix of small Y-shapes that acts as my base module.
  • A surface for the facade, divided into panels with LunchBox.
  • Orient, which places the 2x2 module onto each LunchBox panel.
What I want:
I want each Y inside every 2x2 module to be randomly rotated, so that no two panels are identical and the facade reads as organic instead of an obvious repeating pattern. Ideally the rotation would be limited to a set of fixed angles (for example 0, 90, 180 and 270 degrees) so the Y-shapes still line up cleanly with each other and the panel edges.
The problem:
Because Orient copies the same module geometry onto every panel, every panel ends up with the same arrangement. If I add randomness before Orient, it is applied once to the module and then repeated.
Not sure what the best way to move forward and would appreciate any help!
Randomly Rotating repeated panels.gh (32.1 KB)
Randomly rotating each item inside a panel.3dm (377.8 KB)
You just need to randomize the rotation of the frame on where are placed with the Orient, by generating 4 random options.
Regarding the current outcome, I find it unsatisfactory. A more refined approach would involve rotating the individual shapes relative to an attractor point, utilizing a graph mapper to achieve a non-linear effect while restricting the rotations to four fixed angles.
Thank you so much!
