I have a question about “list item”. I have a grid with “area” points. these points are my middlepoints for two kind of circles. what i want to do is to select a random selection of points. there i want to place the circle with radius 20. at the others (no selected) i want to put the circles with radius 50. so how can i select the ones who are not select right now? do you have any recommendation?
Another question. I used the random method. But now i want to create a special sequence to select the points. I want to have a rythm. A,A,B,B,B,A,B,B and then repeat. A= circle 20, B= circle 50. how can i create that? I tried with range. But couldn‘t get the result i want.
Cull pattern with true, true, false, false, false, true, false, false as the pattern for dispatch and then A - output with radius 20 and B-output with radius 50. (Not at a pc right now)
