So I’m this code to make boids inside a brep and everything seems to work just fine except that I’m using a correct code to generate points inside a brep.
yet it doesn’t work.
can anybody tell me why > ?
here is the code :
public class FlockSystem
public List Agents;
public double Timestep;
public double NeighbourhoodRadius;
public double AlignmentStrength;
public double CohesionStrength;
public double SeparationStrength;
public double SeparationDistance;
public List<Circle> Repellers;
public bool UseParallel;
public Brep Brep;
Random random = new Random();
public Box BBox { get; set; }
public Point3d Min { get; set; }
public Point3d Max { get; set; }
public FlockSystem(int agentCount,Brep brep)
Brep = brep;
Agents = new List<FlockAgent>();
var box = Box.Unset;
brep.GetBoundingBox(Plane.WorldXY, out box);
var min = box.PointAt(0,0,0);
var max = box.PointAt(1, 1, 1);
BBox = box;
this.Min = min;
this.Max = max;
//for(int i =0;i<agentCount;i++)
Parallel.For(0, agentCount, (i, loopState) =>
//var randPt = Util.GetRandomPoint(min.X, max.Y, min.Z, max.X, min.Y, max.Z);
var randPt = box.PointAt(random.NextDouble(), random.NextDouble(), random.NextDouble());
if (Brep.IsPointInside(randPt, 0.01, false))
FlockAgent agent = new FlockAgent(
randPt,
Util.GetRandomUnitVector() * 4.0);
agent.FlockSystem = this;
Agents.Add(agent);
if (Agents.Count == agentCount)
loopState.Break();
It could be that Brep.IsPointInside() has a bug as well. The goal now is to find a specific point which yields the wrong result given your specific brep, and then upload those so we can replicate the problem and hopefully fix it.
Edit: I’m also not at all sure that IsPointInside is thread safe.
@DavidRutten I think the culprit is in the containment behavior . yet it’s code is correct, it worked this morning only when breps were near the origin.
it’s this part from the agent code
if (!FlockSystem.Brep.IsPointInside(Position, 0.01, false))
desiredVelocity += new Vector3d(-Position.X * bounceMultiplier, -Position.Y * bounceMultiplier, -Position.Z * bounceMultiplier);
now when I use this the point bounce off one side and go towards the origin
using System.Collections.Generic;
using System.Threading.Tasks;
using Rhino.Geometry;
namespace SurfaceTrails2.FlockingInBrep
public class FlockAgent
public Point3d Position;
public Vector3d Velocity;
public FlockSystem FlockSystem;
private Vector3d desiredVelocity;
public FlockAgent(Point3d position, Vector3d velocity)
Position = position;
Velocity = velocity;
public void UpdateVelocityAndPosition()
Velocity = 0.97 * Velocity + 0.03 * desiredVelocity;
if (Velocity.Length > 8.0) Velocity *= 8.0 / Velocity.Length;
else if (Velocity.Length < 4.0) Velocity *= 4.0 / Velocity.Length;
Position += Velocity * FlockSystem.Timestep;
public void ComputeDesiredVelocity(List<FlockAgent> neighbours)
// First, reset the desired velocity to 0
desiredVelocity = new Vector3d(0.0, 0.0, 0.0);
var bounceMultiplier =30;
// Pull the agent back if it gets out of the bounding box
//double boundingBoxSize = 30.0;
//if (Position.X < FlockSystem.Min.X)
// desiredVelocity += new Vector3d((FlockSystem.Max.X - Position.X) * bounceMultiplier, FlockSystem.Min.Y, FlockSystem.Min.Z);
//else if (Position.X > FlockSystem.Max.X)
// desiredVelocity += new Vector3d(-Position.X * bounceMultiplier, FlockSystem.Min.Y, FlockSystem.Min.Z);
//if (Position.Y < FlockSystem.Min.Y)
// desiredVelocity += new Vector3d(FlockSystem.Min.X, (FlockSystem.Max.Y - Position.Y) * bounceMultiplier, FlockSystem.Min.Z);
//else if (Position.Y > FlockSystem.Max.Y)
// desiredVelocity += new Vector3d(FlockSystem.Min.X, (-Position.Y) * bounceMultiplier, FlockSystem.Min.Z);
//if (Position.Z < FlockSystem.Min.Z)
//desiredVelocity += new Vector3d(FlockSystem.Min.X, FlockSystem.Min.Y, FlockSystem.Max.Z - Position.Z);
//else if (Position.Z > FlockSystem.Max.Z)
// desiredVelocity += new Vector3d(FlockSystem.Min.X, FlockSystem.Min.Y, -Position.Z);
// If there are no neighbours nearby, the agent will maintain its veloctiy,
// else it will perform the "alignment", "cohension" and "separation" behaviours
if (neighbours.Count == 0)
desiredVelocity += Velocity; // maintain the current velocity
else
// "Alignment" behavior
Vector3d alignment = Vector3d.Zero;
foreach (FlockAgent neighbour in neighbours)
alignment += neighbour.Velocity;
// We divide by the number of neighbours to actually get their average velocity
alignment /= neighbours.Count;
desiredVelocity += FlockSystem.AlignmentStrength * alignment;
// "Cohesion" behavior
Point3d centre = Point3d.Origin;
centre += neighbour.Position;
// We divide by the number of neighbours to actually get their centre of mass
centre /= neighbours.Count;
Vector3d cohesion = centre - Position;
desiredVelocity += FlockSystem.CohesionStrength * cohesion;
// "Separation" behavior
Vector3d separation = Vector3d.Zero;
double distanceToNeighbour = Position.DistanceTo(neighbour.Position);
if (distanceToNeighbour < FlockSystem.SeparationDistance)
Vector3d getAway = Position - neighbour.Position;
/* We scale the getAway vector by inverse of distanceToNeighbour to make
the getAway vector bigger as the agent gets closer to its neighbour */
separation += getAway / (getAway.Length * distanceToNeighbour);
desiredVelocity += FlockSystem.SeparationStrength * separation;
// Avoiding the obstacles (repellers)
foreach (Circle repeller in FlockSystem.Repellers)
double distanceToRepeller = Position.DistanceTo(repeller.Center);
Vector3d repulsion = Position - repeller.Center;
// Repulstion gets stronger as the agent gets closer to the repeller
repulsion /= (repulsion.Length * distanceToRepeller);
// Repulsion strength is also proportional to the radius of the repeller circle/sphere
// This allows the user to tweak the repulsion strength by tweaking the radius
repulsion *= 30.0 * repeller.Radius;
desiredVelocity += repulsion;
